Hello Ray, I can't for the life of me remember what I used for an interval, probably the default setting. The max tightness of you loop likely varies system to system. For the human eye, I cant see why you would need an update greater that 100~200 ms, but of course that is just subjective opinion. ReadCurInterpreterPosition boils down to console commands, so I doubt it is any more efficient. -Brad Murry
Message: 6455 |
Date: 1/13/2013 |
Subject: Re: GUI Update Questions |
OK, I now seem to have MainStatus working OK, and I'm using it to update *some* of the GUI controls. But the position DROs, I have a question. ReadCurInterpreterPosition is, apparently, not very efficient. Is there a more efficient way to get the current position in real-world units? MainStatus is not useful for this, unless I do the conversion from KFlop counts to real-world position, which seems an unreasonable thing to do.
Ray L.
> -Brad MurryTo: DynoMotion@yahoogroups.com
> From: jagboy1964@...
> Date: Sun, 13 Jan 2013 17:10:41 +0000
> Subject: [DynoMotion] Re: GUI Update Questions
> Brad,
> So your recommendation is to let dotNet do the updates? Is a 50 mSec update interval reasonable? Is it more efficient to use the ReadCurInterpreterPosition call when only updating position DROs?
> I do *seem* to have it working now, I think - I needed to do an invoke when I updated the status.
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com, Brad Murry wrote:
> > I had similar issues, which is why I implemented the 'buffered'
> > CurrentStatus Property.
> > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On
> > Behalf Of himykabibble
> > Sent: Sunday, January 13, 2013 9:45 AM
> > Subject: [DynoMotion] GUI Update Questions
> > Tom/Brad,
> > I took a quick stab at re-implementing MainStatus as my primary data source
> > for GUI updates, and it did not go well. I suspect I am saturating the USB
> > channel. I have a worker thread that sleeps for 50 mSec, then wakes up, and
> > updates all the DROs. Every 4th time it wakes up, it updates all the GUI
> > controls. If I update MainStatus every time it wakes up, the app will
> > eventually lock up. Up to this point, I've been using
> > CoordMotion.Interpreter.ReadCurInterpreterPosition() to get the current
> > positions for the DRO updates. I'm assuming this does actually get the
> > positions from the DSP, rather than passing back some cached values, is that
> > correct? If so, I will leave that as-is, and only update MainStatus when I
> > do the update on all the controls.
> > Regards,
> > Ray L.
Message: 6456 |
Date: 1/13/2013 |
Tom/Brad,
Something that appears never to have worked correctly, from at least 4.29z through 4.30j:
KMAxes[String].CheckEnabled();
always seems to return true. This is what I was using to detect a disabled axis, which indicates a limit has been hit. It never worked right. I've now changed it to use MainStatus.GetAxisEnabled(int), and it works perfectly with no other changes.
Ray L.
> Regards,
> Ray L.
> > From: jagboy1964@
> > Brad,
> > Regards,
> > Ray L.
> > > Tom/Brad,
> > > Regards,
> > > Ray L.
Message: 6457 |
Date: 1/13/2013 |
Hi Ray,
I think the function you need to do the conversion for you is the Interpreter function:
ConvertAbsoluteToInterpreterCoord
Which is what KMotionCNC uses. But it is not currently exported in .NET.
I will export it.
Message: 6458 |
Date: 1/13/2013 |
I need to be able to get current position in both Machine and User coordinates.
Ray L.
> Hi Ray,
> I will export it.
> From: himykabibble
> Sent: Sunday, January 13, 2013 11:00 AM
> Regards,
> Ray L.
> > From: jagboy1964@
> > Brad,
> > Regards,
> > Ray L.
> > > Tom/Brad,
> > > Regards,
> > > Ray L.
Message: 6459 |
Date: 1/13/2013 |
Hi Ray,
Good point. I will export:
GC_dll->ConvertAbsoluteToMachine(dx, dy, dz, da, db, dc, &dx, &dy, &dz, &da,
&db, &dc);
also
